Need Chrome Cover for Reverse Housing/Controls
Aug 17, 2013
96
9
Mountains, CO
GW
New extended bars are on -- and chrome switch /control covers --- but have not been able to locate a chrome control cover for the reverse switches --- any ideas other that taking the cover apart and sending out to be chromed?? --- and ---- not sure where to send as my local plating shop seems to have disappeared
TKS
G
You will want HD part number 70213-02C. I have it installed on my 2012 TriGlide. I installed it when I swapped out my handlebars and converted all the hand controls to chrome.
To install it, you will either need to cut and splice the wires that are in the handlebar harness or you will need to remove the wires/pins from the connector inside the fairing and reinstall after running the wires through the housing.
MOCO catalog is incorrect. I had the same issue about not fitting the trike. However I provided my dealer thread discussions on this topic stating it does fit and they ordered and installed with no problems.
Big thanks -- will get it ordered --- just a little gun (parts) shy lately after getting burned on some items that were supposed to fit.
G
G
Wierd, isn't it that the MoFoCo says a part doesn't fit and it does, but there are parts that are supposed to fit and they don't come close. Happens quite a bit on my 1990 FLHS. I think they say nothing fits so I'll give up on a 24 year old bike and shell out for a brandy new ride.
70213-02C is sold in the P & A catalog is sold as a Auxiliary Accessory Switch Housing Kit not as a chrome replacement for the reverse switch housing. I uderstand it is the same switch house and the MOCO should states that it is a Chrome replacement for the reverse switch housing on the Triglide. Maybe the MOCO is thinking that someone may try to fit both Auxiliary Accessory Switch and Reverse Switch on the bars?? Just my two cents.
