Lights on my Tri Glide
Thanks, I've been hit by a car 3 times over my 43 years of riding which all 3 times the driver of the car said "I didn't see you". My answer to them was that "I would hate to think that you seen me and still hit me". So I try to be sure that it's almost impossible to not see me. But even the lights don't help when some idiot is looking at their cell phone instead of where they are driving.
I do my best to be sure Ray Charles could see me, LOL.
Dan
Looks nice, were you get the tour pack side maker lights?
Well to start I installed the FlashR unit from Ride Time Technology:
http://www.ridetimetechnology.com/flashr.htm
It makes the factory side marker lights on the Tour Pak flash with the turn signals.
Then I installed the Lighted Side Trim for Tour-Pak from Kuryakyn:
http://www.kuryakyn.com/Products/4340/Side-Trim-for-Tour-Pak
Plug the lighted side trim in after the FlashR unit and they blink with the turn signals.
Dan
Really nice job. How about the front??
On the front I have The Kuryakyn (made by truck lite) LED Phase 7 Head light and passing lamps:
http://www.kuryakyn.com/Products/4205/Phase-7-Headlights-Passing-Lamps
Also have the Kuryakyn LED halo tim rings for the head light & passing lamps:
http://www.kuryakyn.com/Products/4120/LED-Halo-Trim-Rings
I have also got the independent-control-auxiliary-lamp-wire-harness-kit from Harley:
http://www.harley-davidson.com/store/independent-control-auxiliary-lamp-wire-harness-kit
This allows the passing lamps to stay on when the head light is on low or high beam. From the factory the passing lamps will only be on when the head light is on low beam. They automatically shut off when the head light is switched to high beam.
I have the electra-glo-fairing-edge-light-kit from Harley:
http://www.harley-davidson.com/store/electra-glo-fairing-edge-light-kit
And finally I have the Run-Turn Edge Accents from Kuryakyn that are running lights and turn signals:
http://www.kuryakyn.com/Products/4071/Run-Turn-Edge-Accents
See attached pic's. Sorry the Kuryakyn Run-Turn Edge Accents don't show up in the pic's but I don't have better pic's of them.
Oh and I almost forgot the front fender tip light is a 40 LED board not the factory bulb.
Dan,
They look great.
Thanks for the break down.
I wouldn't have known where to start but you made it easy to pick any combination.
zigzag3227
