Harmon Kardon Stereo
I recently bought an '07 Ultra with a Lehman conversion. The only real problem with the trike is the stereo. When turned on everything powers up but no sound comes out. Has anyone encountered this before? The trike only has 12,000 miles on it. I've not taken anything apart on it and the fella I bought it from said it worked fine and then one day - no sound.:Shrug:
switch below speedo for radio sound on? Push the "tab" button towards you. Also, may have mute setting (as mentioned above) on.
I know it's been several months if not years - but - do any readers have Harmon Kardon radio problems like cracked or broken PC boards?
I have a 2006 Electra Glide converted to a trike in 2008 - the Harmon Kardon stereo broke (similar to above problem)...I sent it to Iron Cross...they repaired it. I put it back together and within 6 months the same thing happened (broken PC board).. Sent it back to Iron Cross, they repaired it under warrantee but not too happy about it. They said trikes are more of a problem than bikes. Iron Cross says it's vibration that causes the PC to break. My guess is lousy OEM shocks. Just trying to find some else experiencing the same problems. What has worked to make the front end if not the entire trike ride smoother? I see various shock replacements running from several hundred to thousands of bucks. Every ad claims to have the best ride...
John in California
roadscholar331
