Tire pressures for h-d anarchy wheels
Oct 19, 2011
2,645
539
Glen Ellyn, IL
Gary
When I replaced my stock wheels/tires with the larger Anarchy wheels, I asked the service writer what the tire pressures should be. He said the same as stock. Even though when I checked the pressures, the rears were at 30psi and the front was 40psi.
Does anyone know for sure what the larger tire psi requirements are?
I did lower the rears to 30 and the front to 36.
I wouldn't see where 36 front & 26 rear would hurt anything, you could double check the side wall of the tire to see what they list for pressure.
I did the same conversion and asked the same question. I eventually talked with customer service in milwaukee and the testers of the wheels and tires for the trike said use the same as the harley manual for the 15" wheels. I called Lehman trikes and they said if too soft a ride add more air, if too rough let some out. so 36 front, 26 rear and adjust to your liking.
dhinzman1
