Need part number for 4 bolts
Feb 11, 2012
509
27
Dickson, TN
Karen
Ok, I'll try to describe this to the best of my old broad ability. I hope that someone has a real parts book. I need a part number for the bolt that holds the turn signal bracket on the front tube. There are two on each side one on the signal bracket and one at the top and they are also a torx head screws. The dealer gave me the wrong number, I ordered them from New Castle HD and they are the wrong bolts. Oh, if you have Dennis' fork wind deflectors then you had to remove them to install the deflectors. Don't ask me why I need to replace them...Wiz will understand!
I'm holding my first and second fingers apart this much to say they are that long....:D
8329 screw qty 4
6702 washer qty 4
4296 screw qty 2
7041 lockwasher qty 2
This is out of my 2010 parts manual for the trike models. FLHTCUTG
8329 screw qty 4
6702 washer qty 4
4296 screw qty 2
I just need the bolts, do you have the size of these. I sure would love to change them to an allen head bolt instead of the torx.
That is what the parts book states they are..No size..
The 8329 is the bolts that goes thru the signal bracket
the other screw 4296 is for the turn signal
Why do you want to change them to allen??
ShonaZiemb
