paint my trike
I think you better do what the "warden" says....and those flames running the length of the long back side panels will look cool IMO. If you go with the batmobile logo.......you have to park it in front of my neighbors house when you come to see me!!!!! :D
:):) Think I would go strips also ,,,besides might be a bad neighborhood !!!!:Shrug: :Shrug:
I think he called that right ,, that's a perfect fit going to make a big difference ,,let us see when finished . ThumbUpThumbUp
I give thanks to all of you for the tips...A big thanks to ABA.....
Well I was board so I decided to see how the decal will look:I should have waited for warmer weather.... May use a hair dryer for better application.. the other side did get some wrinkles.....
Well guys I am pretty much done... added the spoiler provided by ABA....
Not I need to try to find out why the oil lights come on after 30 min of riding.....
That looks really cool Joey, was 82 degrees here yesterday so i went for a long ride of about 40 miles. When i came off the freeway my oil light came on when i was at idle but when i ran the idle up a little it went out. Pulled into a gas station and shut it off, waited a few minutes and checked the level, level was ok.
maybe my idle is to low when the oil gets heated up, i am looking at the 1.5 quart add on oil sump so it will hold more oil instead of just the 2 quarts that it holds now.
Thanks ... Someone told be to replace the oil pressure switch...
Is that oil sump expensive?
Looks DAM FINE BigJoey. You really did a good job on your trike!!! I'm glad you didn't paint the diamond plate on it. You can park it in my driveway now!ThumbUpThumbUpThumbUpThumbUpThumbUpThumbUpThumbUp
Bullet Proof
