What is causing my Triglide to die?
The on/off switch on the right grip could have come loose. Also. Our old EG had a bank angle sensor go bad and would kill the engine unexpededly. But not sure if a TG has one.
PC
I got a feeling my FOB battery was on the way out...Bought some new batteries and once I get the bike back together I will try it again..The tank is off now while I run some wires in the duct that is under the tank..plus I get to clean my cylinder heads..
Verdict is in...... Fuel gauge was faulty. The gauge said 1/2 tank, but was empty! That explains what was happening...new part should take care of the problem.
I'm just glad it's finally fixed. Thanks for all of your comments and suggestions.
Wow, great to hear its an easy fix.
I have never put stablizer in my gas and never goes bad. It is in hear but when I didn't have heat I still had good gas. Now 2cycle is another story. Guess I'm just lucky. I used to be a small engine mechanic so I know what it smells like took enough carbs apart that were shellaced up. I've got a generater,power washer and tractor that has nothing in them and they sit for along time,still good.
Most motor gasoline today is laced with ethanol which performs poorly after extended storage. You might want to rethink using a fuel system additive prior to putting the engine in storage.
We could not start our trike this morning. It would fire...but die immediately. The turn signals flashed in a weird pattern. I remembered someone said to try a new battery in the fob. That was it! Thank you for the info!
zigzag3227
