Oops, Tri-Glides don't do well underwater.
Screwball, Trent beat me to it. If you turned left you really would get wet - screw the rain. ROFLMAO.
I do disagree with you about the DFT standard bodies though. I can't stand them, but I do like the DFT Harley designed one.
I decided to buy a new TG instead of converting my 2010 Limited because I wanted a ground up factory designed trike not something I would have to heavily modify and hope it rode well.....and get a 7 year factory warranty to boot.
I bet I would only be able to count on one hand how many times in the last 50 years that an IRS would have been worth having.
This is just me now, but I can't see spending $8000+ just so I can ride over a pothole or two maybe once in a week or month. I do not ride on bad roads-as a rule-granted there will be times I can't help it, but I will slow down while I'm on it. When I encounter a road hazard, pothole or manhole cover, etc. I will hit it with the front wheel and NOT the rear wheels. It's so much softer that way believe me. That was the very first thing I learned.
If it was a $900 option, I probably would convert a Tri Glide.
Those with back problems I don't blame you for a minute on wanting to do whatever it takes to be able to keep on riding. That's why I bought a trike in the first place - so I can ride till I'm 80+ GOD willing. ThumbUp
I have been running 16 # in my rear tires for the past 6 months or so--- can't believe the difference in the ride and i can see no wear on rear tires
I have ridden a lot of miles with IRS and solid axle both and actually prefer the solid axle for stability---the difference in ride i found to be neglidgable----in fact i think i would pay extra for the solid axle if i had to.
I think a tire pressure poll(if there hasn't been one) would be good. I just lowered my rears to 25lbs from 32, while keeeping might front at 41lbs. The ride is definitely better(softer and more controlled).
I think I'm going to try 20 in the rears, as they are Z-rated, with, I'm assuming very stiff sidewalls. I'm actually going to call the mfg and see what they say.
The rears on my trike are the same size, aspect, and speed rating as on a sports car I own. I keep all tires at 36lbs. I'm sure it's what goes between the tires and my butt(including air presure). I drove it from Pgh to OBX last fall with only one stop. Two days later, I drove back with no problems. I also have a 1 ton dually that I can drive forever(although usually towing a large trailer for long distances). In my wife's minivan, 60 miles and my back feels like crap
If mfg says 20 is safe, I'm going to try it.
I am not concerned about the sidewalls. These tires are designed for vehicles weighing thousands of pounds, The weight of these trikes with two up do not even show the tire's sidewall buldging. Like i said i have been riding all winter with no adverse effects
