It still takes volumes of oil, unless you have a way to cool it down in High Humidity with 103 in the shade. Sun shining, sitting in a traffic jam with engine idle.
That when Harleys rear cylinder is off line.
A oil cooler with a fan will cool it down, just like aircon/radiator fan on a car.You could have 6 qts of oil and once you get caught in some stop n go traffic you will then have 6 qts of very hot oil. The oil volume won't do much for an air cooled dry sump engine such as the Twin Cam. If it took riding 10 miles on an 80 degree day to heat up 4 qts of oil to 230 degrees it may take 15 miles to heat 5 qts up to the same temp.
Thermostat turn it on around 160. to 170. depending on how it is set.
