Fellas....Since joining this Fine site I've been totally inspired by the ingenuity of so many people that frequent it
I have several Ideas that hopefully I'll find the wherewithall to apply in the coming months(If I can find enough$$
I have another Idea I'd like to share:How bout off the tailend of the motor...a 90Degree transfer...a shaft where the motors power output is simply going into an angle drive!! The reason for such would be to enable one to drive a 5 speed Motorcycle transmission!!!
A little creativity would allow for anyone with a solid fabricating background to take the VW motor and use it for a mid mounted set-up and siamese it to a relatively compact Bike trans.....of which could be had from JIREH or Midwest motorcyle supply for about 500-550$. I'm not 100% certain how I'd go about hooking up the 90Degree drive of the flywheel....but the center of the flywheel would have to be modified to accomadate a shaft....the shaft would go to a small box consisting of 2 pinion gears....the out put shaft would in turn drive the transmission via chain and the final drive chain would go to a straight axel drive set-up such as a DNA or frankenstein rear.
Wadayas think?
Wadayas think?
