Unknown code
Rogue1
400+ Posts
Oct 8, 2018
582
620
Ramseur, NC
Dale
I am displaying a code that I can't find in the 2019 Tri Glide DTC list. Or anywhere for that matter. It's U2067. The U codes don't go into the 2000's.
It first appeared after I installed the Dakota Digital dash. Keeps coming back.
Wether are not you removed the battery leads, check them for cleanness and proper torque.
That code dosnt exist in my '18 Electrical Diagnostic Manual. It may be a Dakota Digital code. Call them, they are very helpfull and may know what it is.
All U codes are lost communication codes
Pull your main fuse, disconnect and clean both battery cables, reinstall the main fuse
Scan and delete all codes. Restart bike, shut it off and recheck for codes
I too cannot find any such code. Are you sure you read it correctly? I also have the Dakota Digital gauges (MLX-8414) and while I really do like them they have some inherent flaw. I've had them blank out momentarily and then come back on. Sometimes throwing code U0156, lost communication with speedometer. A couple times they have not come on after starting the engine and I've had to shut down and restart several times to get them back on. And I've learned I am not the only one having such problems - my local dealer service manager has also and I've found some internet chat and even YouTube videos about this. They have replaced them but seems to me there is some inherent problem with the gauges and my bike is not causing this.
I have seen the same glitch with my Dakota Digital dash. When that happens I throw a u2067 code. Which like I said before I can't find anywhere. I have pulled the main fuse cleared the codes and replaced the fuse using dielectric grease. But I still don't know what the code is.
yrral
