Turn Signal
Jun 26, 2009
51
Ahwatukee, AZ
Ron
My 2000 Valkyrie Standard/DFT tike...............the left turn signal blinks real fast but the right one blinks normal, I've changed the relay, disconnected the rear from the front and even changed the front light, so I know it's not in the rear of the trike, so now I'm just lost.
Culprit is likely a bad ground. Hard to tell "where" it is so you might consider running a new ground from the light fixture. Good luck .......
We're did you get the bulb? I found some auto bulbs not compatible with the flasher... Did you change any?
danford
