TTS Mastertune
Question about the TTS mastertune....I have a powercommander V with autotune and so far it works good. From all that I have read, the TTS system is far better than what I have. Question 1....Can I upgrade to the TTS from the powercommander by simply removing it from the ECM. Question 2.... What are the advantages of using the TTS? Thanks for any advice
Gary
Yes. Pull it off and follow my PDF directions.
Several... You are using the smartest thing on your bike, the ECM. If you use a PCV you are trying to fool the ECM into seeing something that is not happening on your bike. Several of the ECM harness wires are cut in the PCV harness making the ECM useless in several areas of programing. The TTS flashes a new calibration to your ECM, a calibration that is adjusted to your motor and combinations. The software is easy to use yet sophisticated enough to tune the most complex bike.
I think I got the tune for the trike installed yesterday once Mr. Wiz told me which tune was appropriate for my trike. When finished I went back and checked and the tune was listed. Now, how many days until spring?
way to long before spring..
LuisTanaka
