Tts mastertune sert qualifier
Oct 13, 2010
2,591
211
Illinois
Trikermutha
Has anybody used the TTS Mastertune SERT Qualifier software?
I am assuming if the bike and SERT qualifys TTS updates the interface to be used with there TTS software.
And has anybody used it with there TRI Glide once upgraded??
I've used it many times. Have never found an old SERT that didn't qualify. Only takes a minute to run the special software from the TTS site and you must print and send the txt report with the SERT to TTS.
Each time the SERT was replaced with the TTS and it worked great.
-wiz
-wiz
:Agree: My 06 Ultra used to be tuned with the SERT, I run the qualifier and now its tuned with the TTS. I also now have it setup with O2 sensors and some of the areas set to run in closed loop.
btw... this is not to be confused with the SEPro tuner which came out in 2008.
Here is a picture of the older style SERT.
mtorcyclejoe
