Trunk on Lehman Conversion GL1800 will not open
Jan 7, 2012
2
Lake Placid,Fl
Trunk on Lehman Conversion GL 1800 will not open
Looking for a solution for opening the trunk of my goldwing lehman conversion. The cables have come off in the lower trunk and I don't know how to get to them. Help is appreciated.
Re: trunk on lehaman conversion Honda Goldwing 1800 will not open
on my motortrike all i had to do was open the top trunk there is a plastic cover right at the back the cables are right there I think it was 4 screws and off put the cable end back in and put a tie around it so it dont happen again.....Very Easy
Thanks, but my cable is off at the other end, I had already checked the cable end you are referring to, but it was secure. Any other suggestions are appreciated. Also the emergency cable under the seat to open the trunk will not open it either.
Have you tried one person pushing in on the trunk lid (to relieve tension on the latches) and another person pulling on the emergency cable ?
did you ever get your trunk to open? I am having the same issue, the regular cable doesn't work, like it's binding up and the emergency cable broke.
RCK TMS trike
