Trunk Lockset Question.
Jul 12, 2017
109
26
Blacksburg, VA
Bill
The push button on the trunk lockset doesn't bounce back when I push it in to open the trunk door. Anyone have/had this problem? How did you fix it? 2015 tri glide.
Ya I hate when that happens ! Try a little 3 in 1 oil around the knob and work it. Hopefully it’ll pop out. If not then the inside cover has to get removed to get at it. Good luck.
Yep, needs oil. Also, I notice, the colder it gets, the stickier it's gets. During winter, I just use my key to pop it back out.
I lube my lock button regularly any time it even starts to feel stiff. Triflow is good stuff and my bottle has a very fine tube so it is easy to put a drop on it. 33K and no lock problems.
Bob :Dorag:
FlintM
