Since I purchased my classic 1998 GoldWing with a TriKing kit, is there any maint. on the kit that I need to do? Thanks in advace.
the bike itself has been checked and maintained properly, I was just wondering about the kit. Thank you for your replyNot familiar enough to know particulars of a TriKing, but if a solid axle, check or change rear axle lube. Brake pads or shoes could be looked at. Brake & clutch DOT 4 fluids. Spark plugs? Oil & filter in engine? Driveshaft & U-joint lube The bike itself has neem maintained and gone through....ess eondering just abput the kit...thboth in any grease zirks … splines at rear of engine maybe could use grease but will require removal. Coolant? Air & sub & cruise filters? Check swing arm for any play side to side, likely it's bearings at pivot are greased but ??? Fuel filter? Battery age & condition?
Watch out for gas pump islands.
Oh, well in that case, just add rear axle, swing arm, & driveshaft stuff. Things like fluid levels, leaks from axle seals, pinion seal, U-joints maint, swing arm bearing check for looseness.the bike itself has been checked and maintained properly, I was just wondering about the kit. Thank you for your reply
