Trike won't turn over
Apr 2, 2023
6
8
Minersville
I have a 2012 triglide I changed the bars and the radio got it all back together, it ran good then would go into limp mode ,tore it apart several more times, found a bare wire on the TBW put a new TBW in and now it won't turn over and everything else has power, also my power vision is saying there is no ecm. I can't see any blown fuses or tripped breakers. Any help or advice would be appreciated. Thanks
I do have the stock tune but can't load it because the the tuner says there is no ecm. I unplugged it and still nothing, is there a way the security system could shut it down like this, i noticed the red security light goes solid and stays on. I have changed fob batteries and tried a different fob. Any other thoughts. Thanks
Pull all fuses out, clean the ends and reinstall them, pay attention to any fuse( main fuse) for any wiggles in the fuse holders
Give Fuel Moto a call
Phone: (920) 423-3309
Is this your fuse box? Pay attention to fuses #3 and six
Just my thoughts......But in my experiences a bare wire will almost always lead to a blown fuse, Or a dead short on a component ....A bad fuse will some times look good even when it isn't..New fuses are inexpensive ...I would change them all.:Shrug:....
If it worked fine before you fiddled with it then the problem is the nut on the end of the wrench.
dhinzman1
