trike troubles.
Sep 4, 2013
769
122
Poplar Bluff, MO
Tom
Im riding a motor trike /08 ultra conversion.
took a ride yesterday about 90 miles . Had some intermittent missing in the engine with acceleration. not too bad but noticeable . worse at lower r.p.m.s .
as we do a lot of back road rides I figured maybe I had again got some bad gas.
turned left at a cross rode and started to accelerate and the throttle had no response. motor kept running at about 1100 rpm but would not accelerate. It was about a mile to our next stop so I let the clutch out and idled to the stop. I shut the bike off and waited about 5 min. I started it back up and it was fine. the throttle worked and we drove it home . motor still has the miss and I am going to drain the tank and flush it , but ????? why did the throttle do that and is it something I need to look further into ? I guess I will know more when I get the gas thing figured out.
I was going to say if it was a new Harley, I'd take it to the dealer and let them run the codes, but I don't think you have that ability. I'm not an expert, but I don't think gas has anything to do with what happened because the bike kept running. I could be wrong.
Good luck
Have you checked for any error codes? Does that model have a throttle cable or "fly by wire"? How are the gaskets from carb/fuel injection to cylinders? Try spraying gumout between cylinders (while idling) and see if engine rpm changes/tries to stall out.
Interesting that you would write about this issue. Last week I washed my TG ( first time in about 3 months! ) I put a shower cap over my open air filter as I always do. After I gave it a good blow dry, it started right up and did the exact same thing that yours did. Would idle at 1100 rpm's, no throttle response at all and the check engine light was on. So I got it into the garage, let it sit a while and tried it a couple more times,,, no change.
Called my HD tech at home and told him the issue. He told me to unplug the wires going to the breather and blow both connections out with air, let it sit a while unplugged , then plug it in and try again. I did that and then it worked fine. Water had gotten into the connection.
He told me that the computer will sense when something is wrong, and shut it down to that idle speed if it decides the problem will not damage anything, just enough to maybe get you off the road or to an exit. Yours must have done the same thing because of whatever the problem was, or is. Maybe it sensed bad fuel and did it for that reason. Did the check engine light come on?
no engine light came on. I had the missing problem once before from putting cheep gas in it. After I drained out the gas and put some 93 octane in it was fine. I don't know if it was that one of the sensors didn't like the gas or what. Just like you said it had no response to the throttle at all, then after shutting the ignition off and turning it back on I guess the computer must have reset. Going to try cleaning the tank first. I know how to do that and it doesn't cost a lot . thanks for the heads up on the connection cleaning. if the gas isn't the problem I will give that a try. Now a stupid question : there is a computer separate from the tuner right? (my last problem child Harley had a carb.)
I think it wire . don't see any cables . good idea with the carb cleaner. use to check auto engines for leaks that way. didn't think about it. At the time I was a little frustrated and not thinking clear. 90 miles from home . when it started back up I was thanking the biker gods for their mercy but want to figure it out before riding out of town again.
When was your fuel filter replaced? May want to replace the,pressure regulator as well. @ 25k miles the fuel filter should be replaced.
Vapor lock can occur after filling up while the engine is hot. I had this issue and needed to replace the fuel supply line from the tank to the tee that feeds the injector rail. Havent had any issue since.
going to have to get out the service manual. I have had the tank off before and don't remember seeing a filter.
drained the gas tank , changed the fuel filter, and refilled with 93 octane. back to normal .thanks for the help guys. ThumbUp
Tom W, I can assure you your problem may have corrected itself while you switched to higher octane gasoline, but the octane increase itself did not correct the problem. I spent 15 years making gasoline for Gulf Oil so I'm very sure octane does nothing but raise the ping resistance of your engine. Nothing. It doesn't make your gas burn faster,cleaner, cooler, smoother, etc, etc.
You may have a temperature sensitive sensor, of which there are many, that could be aggravating you. I hope this problem clears up for you.
Phu Cat
+1 to Phu Cat. The filter change might be more likely what corrected your problem. All the stuff inside the tank can start leaking or get a hole in it and you never know until it starts acting up. The dealers have pressure checks they can do to check all those hoses and connections out. But if its running well now I expect the filter had a lot to do with it.
TomW If you have the service manual You should run the test on the MAP Sensor and check its connections. If the ECM thinks it lost signal from the MAP sensor it will do what you described.
I don't know a lot about the ECM or computer stuff. I know that all is well now so was it the fuel was contaminated ? was it the filter ?( and it was dirty) .:xzqxz:.
just happy it was that simple to fix. the fuel pump even sounds different now.
Ok, now the gremlins have returned ! after about an hour long ride I shut the bike off and took a short break. started it back up and moved about 50 yards and it happened again ! no throttle response. kept running at idle speed only. tried several times to restart the bike and it would not start. after about 20 min. it started and ran fine.
I tried to run the diagnostic codes and can not get the bike to flash the codes.
I am not a tech guy any body got any ideas ? I took all the connections apart and checked them at the e c m and the tuner. found nothing obvious. could it be in the throttle sensor or in the e c m ?
How does the fuel pump sound? Do you have any friends with a bore scope that you could use to look inside your tank for contamination? Especially look at the lowest portions of the tank .... and the fuel exit area. The fact that you had a dirty filter the first time leads me down the path of a fuel delivery issue. Ethanol fuels can really suck!! I use Berrymans B-12 fuel system treatment in all my vehicles at least twice a year (autos & cycles). My cycle with carbs gets Startron added at every fill up. My new 2014 Tri Glide will get Startron added while she sits over the winter months and gets very limited riding. I always keep my fuel tanks full.
Bob :Dorag:
when the motor would not start the fuel pump continued to run. and the engine light came on . after several attempts the pump and engine light went off and it started. what makes me wonder is why I cant get it to read the diagnostics. Cant get the code to know where to start looking.
I replaced the fuel filter and cleaned the tank out last time this happened. not that long ago.. replaced the spark plugs last week. It does run better when it runs but don't want to get stranded out some where. I have been looking and found a service bulletin #tt418a that deals with the throttle sensor and e.c.m... looks like another trip back to Harley heaven (the dealer)and more money.
Hi Tom,
Harley calls this "limp mode". I had the same problem my '11 TG. There is an electrical connection right behind your air intake that gets wet and corroded. Take it apart and blow It out with an air compressor. After it Is dry apply some dielectric grease to the connection. If that doesn't work you may have to replace the connection. I found out the solution on one these forums. I believe it was Mr. Wizzard that had the same problem.
I traded the '11 in on a new '15 about a month ago...... Love all the new gadgets.....
Hope this helps.......
Gary
Hi Tom,
Gary
Tom.. This is what I had to do to mine, as I mentioned in an earlier post... The tech told me it only takes a tiny bit of moisture in that connection to send it into limp mode..
thanks that will be my next attempt. haven't started pulling my hair out yet but getting a little frustrated. our next sched. ride is the snow balls ride jan 1 . hope to get some sunny days before then to give it a try. I sure don't want to be stranded jan 1 and have to worry about it.
Hey Tom,
Go to google search and type in Harley limp mode. You'll be surprised in the number of responses. :confused::confused::confused:
Good luck........ Weather has been terrible here in Ohio.
Gary
Ha ha!!! Snow Balls Ride huh?!! What a great name for a Jan 1st ride! Here they call it the Chilly Chaps Ride. I like your name a lot more!!!
It is a much better description. ;)
"Chilly Chaps" ride is 3rd Sunday in February Trent....no wonder I haven't seen you on that ride (lol)! January 1st ride has no name...just a New Year's Day Ride. We need to promote a new name...Snow Balls Ride!!!
Feb??? Huh... Maybe that's why I am always by myself on New years day...;) I like the Snow Balls Ride title!!! Best one yet!
Hi Tom,
Gary
Would really appreciate more info on this connector --- like where exactly is it and what does it look like?
Tks
G
Tks
G
If you remove the air filter backing plate. Its on the left. The small tab on the backside of the connector needs to be depressed to remove the connector.
I have a few questions...
1) How many miles on the engine?
2) Is the stock or stage 1 type air filter setup being used?
3) If so, is the head breather setup stock?
4) Can you push the throttle blade open ( Its stiff, and will require some force ) and look into the throttle body bore with a light and see any oily black mess in the bore?
If the bore is gummed up, its possible the MAP Sensor is dirty and not working correctly. HD # 32319-07 there is solvent specific for MAP sensor to clean them. They have to be removed and sprayed down while keeping the top upright so not to get any solvent cleaner in the electric top. The MAP Sensor reed needs to be clean to work correctly
Another problematic sensor is the Crank Position sensor. HD #32707-01C Most of the time when they go bad, the engine wont fire at all.
Tom
Tom
it was a dealer built 110 s.e. larger intake and stage 1 air box. high flow heads.
has close to 15000 on the build and almost 20000 on the original bike. had a power commander put on and dynode about a year ago after a cam change. I was told to look close at the power commander for cracks. none found .
The ride title was from our group. you either snow balls or no balls.
it was a dealer built 110 s.e. larger intake and stage 1 air box. high flow heads. has close to 15000 on the build and almost 20000 on the original bike. had a power commander put on and dynode about a year ago after a cam change. I was told to look close at the power commander for cracks. none found . - - - Updated - - - The ride title was from our group. you either snow balls or no balls.
One way to rule out the Power commander is to un-hook it and then fire it up just off the ECM, it'll run like sh!t but all your looking to do is check idle rpm and see if it will rev up past limp mode. and not go for a ride. I know of one person who had erratic running issues with a PC on a Triglide, he took it off and went straight ECM and found the PC had taken a crap.
Thanks -- that is the info I was looking for
well, I started it to move it out of my way to do some welding Saturday morning. It started fine ran about 30seconds and quit. will not re start. unhooked the power commander and still will not start. went to the dealer yesterday and got contact spray cleaner and the grease . going to clean all the connectors and re grease them after inspection for loose or bent pins. finally got it to read diag. gave me a large list of codes. I looked them up on the computer . most deal with the throttle sensors so I think this is probably the problem . I found this is a common problem on the 08 ultra, big motor, with over 20,000 miles. some even go into pinched or broken wires. it may be a long winter.
this seems to be common as the dealer told me the same thing. it didn't make a difference with mine but .........
QuyenDevin
