Trike Towing
Status
Not open for further replies.
Jan 17, 2010
82
3
Northwest Ohio
Joshua
Does anyone tow there trike? What do you use a trailer or a tow-bar? I want to drag my trike down to Florida. Who has a good solution? I have seen some nice hitch mounts and dollies. I'm open to suggestions. I grabbed some pics off eBay. The dolly is in Europe so it wouldn't be economical to ship it here compared to building or purchasing one. Check out these pics.
That looks good but I personally think for long distance towing all 3 wheels off the ground is the way to go if you can find a used car towdolly and then stretch the front of it with channel iron and some bracing you will be better off ,then strap the rear wheels down were the car tires would go and tie the front wheel and away you go .hope this helps and not confuse .
What about renting something like a U=haul trailer or one of the other rental trailers ?????
I would worry about the clearence of the kit to the road, if I had it on one of the dollies like U are talking about???? Plus that would be a lot of stress on the steering head bearing....
Katfish,
I have a tow dolly like Big Al is talking about and I use it to haul trikes for delivery to customers and it has been all over the country and no problems with it or the trike on it,
easy to make
Ray
Hey, glad it works for U... he asked and I gave my opinion.. U have the real thing.. With my luck though I would break something..
Thanks 4 ur reply and for the information..
if anyone needs a towing device for towing your trike, I will be glad to build you what you want for the cost of the materials and we will call it even on the labor, to me it is all about helping a fellow triker,
Let me know if I can be of help.
Redneckray
If you ho to my albums, you will see what I use for towing a trike, and easy to make too, grinn
Ray, what U R using is what we used to call a T-rail... what he had the picture of was one that U put the front wheel in and let the 2 back wheels stay on the ground...That is why I said I though it would be a lot of stress on the steering bearing...
We used to use the T-rails for hauling our rail dune buggies....
Similar to a T trailer, but the rear wheels are off the ground to haul a trike, but a T trailer will work too and cheaper too, no need for rear suspension on the trailer, the tires are it,
In Florida yes you would have to either put added lights at the rear or wire to activate the lights on the trike for running brake and stop. <br />
<br />
Redneckray I like your trailer.
I tow the giant killer 3 off the ground without a trailer, never have to tie it down or worry about someone stealing my trailer:yes:
Hey caveman,<br />
that is a good idea you have there, can you share with us on how to do it for other trikes<br />
Thanks,<br />
Redneckray
yeah ray, I just attatched two torflex stub axles to 2 inch square tubes, which slip into 2 reciever tubes welded to my rear frame, on the front i made a hitch that pins to the front of the trike with 3 pins, takes about 10 minutes to get from transport to in the wind, oh also i have a trailer plug mounted in the front of the trike, hook up short jumper cord to truck & trike lights operate with truck lights. rides smooth at any speed. There are some poor pics of this setup in my profile. Poor Mans Trailer LOL, Caveman
Hay yall, I thought an update would be nice. I found a car dolly. My plan is to stretch it out and run the front end on the goose neck and the rear on the dolly. I think they are called T rails or T trailers. Thanks for all the good advice!
Run the front wheel about 3 feet from the hitch and you will be good to go, it looks good, you find anymore?
there around. Do you have the Auto Trader down there? I hear thats the place to look. This one fell into my lap. I was lucky....wow I never get to say that.
That looks to be a fabulous set-up 'cos the back wheels are off the road.
A friend of mine towed his trike to an AGM behind his converted bus on a dolly (with trike's rear wheels on road) ... It was a long distance haul and his trike
suffered extensive damage to chassis & bodywork. He now tows it on a full trailer. Personally, I like to ride my trike to the destination... just LUVVV the journey.
I've never owned a trailer queen. I'd rather ride too, but the 10 inches of snow we always have on the ground in March makes it easy to make up my mind about riding down south. So a trailer gets me to were I can ride. I hope it pulls nice behind my bus.
Status
Bullet Proof
