I made these a few months ago and they work great for changing oil and getting under the trike. They are made from 3-8 Ft. long 2x8 boards. Stack them and cut them 32" long. Should make 3 pieces. The flat part where the tires will rest is 12" long. from the 12" mark you can scribe your angle to the 32" end. This will give you an easy angle so it will be easier to drive up on. On the front section you will notice that it is cut at the end of the 12" mark and has an aluminum piece on each side. This is just what I had to lock the 2 pieces together.
You could use screen door hooks. When you get the trike up on the ramps you can take the angle piece out from under the trike for more room and get it out of your way. I found the handles at a discount hardware store for 1.50 ea. Note..only screwed a few screws so it would not interfere with the saw. After the angle was cut we went back and screwed in the rest of the screws on the angle portion. We had a large band saw to cut the angles. Think I have less than $20 in this and it works for me. Some of you trikers I am sure, can take this and come up with something that will work for you.OH! the front safety stops were made from the scrap angle pieces.ride safeThumbUp
