Trike pulling to right
I recently replaced rear master brake cylinder on my 2007 Ultra Classic Electra Glide with Lehman Renegade rear end. Bike now pulls to right when rear brake applied. Bled lines extensively, still pulls. Can I adjust brakes without pulling wheels?
Herb,
Welcome to Trike Talk from West Virginia.:wave4:
If it didn't pull before, and you didn't change the brake adjustment (assuming you have drum brakes), I would think that it may have air still in the system.
Happy Easter
welcome aboard Herb. Jim is our Lehman expert so keep bleeding the brakes. You got air in there still. Check and make sure your fitting are tight.
If drum brakes, if not pulling before, likely not adjustment … but do look inside the rear wheels from under rear of trike for any signs of leaking rear axle lube from axle seals. Rear axle lube on brake shoes will cause them to grab, and they are ruined when it happens, no cleaning soaked brake shoes …
RogerHol
