trike conversion
Nov 16, 2011
21
wayne, wi
Hello to all. my first posting. Looking for some feedback. I am thinking of a trike conversion for my 2001 ultra. The Frankenstien conversion kit seems pretty decent, it seems to be well built and for the dollar a good deal, any info, good or bad, would be appreciated. Champion trike is being considered. Has anyone heard about or dealt with Kool Trikes(kooltrikes.com) out of Wisconsin? I am leaning toward a straight axle versus an independent axle because less parts means less can go wrong. I have read several different post both pro and con about the independent or straight. I am looking for any info from mpg reduction to handling to trike being extra hot to ride.
Steve
The Frankenstein is more of a performance and sporty kit, but I think they are good products. Champion is a good choice if you ever plan to ride 2-up, or make longer trips.
JMHO....but stay with the straight-axle. It will be less expensive and simpler. You do not sound like a guy looking for a rocking-chair if you are talking Frankenstein, so you will not be bothered by the little stiffer ride the straight axle will give you. The current Tri Glide is a straight-axle design and you don't hear many people complaining about the ride. Go look under the front of your car and make a note of all the moving suspension parts...then go look under a Tri Glide, or the rear end of your pick-up and you will see what I mean. I am not bashing the independent suspension folks, but you can't argue the fact that a straight axle will be simpler to install, easier to maintain.....and cheaper.
Fuel mileage will likely be in the mid-30's on average on that converted Ultra with the Champion. Handling....once you get use to it and have it properly set-up...you can take a curve with any 2-wheeler....well...except a crotch-rocket maybe.
Steve
welcome aboard. 07 RK with Champion straight axle. Great conversion.
One of the reasons I am leaning towards Frankenstien because I like the fact that I get to keep the original swing arm if I want and also the triple tree is included. A body can allways be added later. But Champion is still very appealling. Thanks for your input.
If you want to look at a terrific IRS kit, check-our Roadsmith. No maintenance design. I've had both (solid axle Motortrike / 89 GL1500) and IRS (Roadsmith / 2010 GL 1800)...Pros/cons on each. Handling generally better on IRS rig (but, I adjust tire pressure and that makes a big diff. on twisties). Solid is simpler design, but, Roadsmith IRS doesn't require any mainenance, either. If somethng goes wrong in the back you're fixing it regardless. MHO -- The mechanics/safety on all name brand rigs are very good today, so, I'd play that selection criteria as a "wash". I'd choose the kit that you like based on looks and ride -- both of those are personal.
I put Frankenstein's narrow "Sport" rear end on my Dyna. I love it! Of course, I have not had another trike to compare it to....I can tell you that Dan does not like to ride behind me on a rough road, he says it freaks him out to watch the tires bounce :D but from the drivers' seat she stays just as straight as on brand new pavement. With the heavier Ultra to start with I don't think you would have the option of the narrow axle - and it is solo rider only with my set-up. Frankenstein has a bunch of options, though. With what was a slight "custom" installation, we called the factory a couple of times for help and they were GREAT. The machine work on the kit was amazing; the tolerances were precise and instructions - with photos! - were easy to follow. I really liked that I sent them my swingarm & pulley - and they mounted the pulley to the axle so I didn't have to worry about alignment, torque, etc. A couple of things that I didn't realize until the pile of boxes arrived: 1) you will need to powdercoat the swingarm if you send them yours; 2) fenders also will need paint; 3) take the kickstand off when you install the rear end :) and 4) if you don't already have short exhaust, you will need to do that too.
There are photos of the build on my profile, I think....
Geezer Glide
