Tri Glide Reverse Motor
I've had 4 Tri-Glide's over the years. 2011-2017-2019 and a 2022. I've only had the breaker pop 1 time. I use my reverse after every ride, to get back in the garage. Other than the one pop. Everything has been great.
Not every reverse was defective….It’s just the luck of the draw….The same as the transition oil migration to the primary on the 2017 Tri-Glides…
Bob is right, the reverse is ill tempered and bad JUJU happens all the time with this poorly designed system
A rebuild kit is ok, but trust and verify all sources
Flyboy7312
