Tri Glide Cragar/American racing wheels
Welcome to Trike-Talk.. Jeff i can't help on the wheels but i'm sure someone will come on soon with some help...
Welcome Jeff,
Rear wheel is a mustang 4 bolt, 2.25 or 108mm pattern
wheel is 15x5.5 with 2.85 backspace.
You can use a 6" wide wheel with a 3-3.5" backspace (offset) using a 205 tire.
Centerline thruster #806 5806 442 is the closest I found.
Kinda gave up, after powder coating mine , the end result was better than amagined :clapping:They were in tuff shape from previous owners abuse.
Stand by , as others will chime in , for sure. Good Luck 👍🍀
Unless someone can give you info on changing the hubs to five lug Cragar SS wheels aren't going to work as the spokes go the whole way to the center of the wheel and are 5 spoke/5 lug only. The only 4 spoke/4 lug Cragar SS wheels were 13" made for Fox body Mustangs. All 15" Cragar SS wheels are 5 spoke.
Not enough room to use an adapter/spacer, unless you also buy Yaffe's wider fenders.
There are lots of wheels out there that will fit a TG or FW. Just know that many will not.
Do a forum search as I've explained the numbers you need to know, to get a correct fit.
nmbr1soonerfan
