Campers out there, does anone use a popup? if so what brand, and your experance with it.
There are two of us. Getting to old to sleep on the ground!!
Campers out there, does anone use a popup? if so what brand, and your experance with it.There are two of us. Getting to old to sleep on the ground!!
Kevin,Yes, we have a Lee-sure Lite pop-up.
In the past we've had a Time-Out and a Bunkhouse...both of these were pulled behind 2 wheelers.
We've enjoyed all three of them. The Bunkhouse is the largest, and was the most comfortable. If we had had a Trike at the time, we would have kept it, but felt it was too much wind resistance pulling behind 2 wheels.
We started using pop-up tent trailers for the same reason...got tired of sleeping on the ground.
We are able to take everything but the kitchen sink.
The Lee-Sure Lite is by far the easiest one to set up and break down. It has a Double bed.
The Bunkhouse is easier to pack and has a King Size bed. It takes 15 minutes to set up instead of the 2 minutes the Lee-Sure Lite takes.
Lee-sure Lite
Here's a pic of the Bunkhouse-
Kevin,
Thanks for your input. We are both large people, and the Bunkhouse with its king size bed would be best. We have been looking at all 3 that you mentioned but were leaning towards the Bunkhouse even with the longer setup time. I am happy that you would stick with it if you had a Trike at the time. Would you consider the break package you can get with it?
Ken
I have a friend trying to sell his camper trailer over on the gl1800riders board. If interested I will get his phone number and email address for you. It is located in NH but he will deliver or meet somewhere to deliver.
Here's is ad on that board:
2007 Trailmaster Aspen Sentry Camper w/Brakes*![]()
2007 Trailmaster Aspen Sentry*
Queen bed. 325 lbs empty*
Lockable Full Storage under the bed is accessible while on the road or while set up in camp via a lid in bed board.
Black body and travel cover with the storage pocket in the cover. Blue and White Tent*
Rear bumper with reflectors. 4 stabilizer jack stands.
Optional Electric brakes and controller. This is the Very best option! I can still play in the corners some as compared to without brakes on the trailer(had an 06 Sentry without brakes)*
Optional Swivel hitch with lock.*
6 pin round connector.
Handle on tongue to help moving the trailer around site.*
All lights work good.
Cooler rack and cooler with matching cover.*
12" Chrome wheels and good tires.*
Spare tire(white spoke) with custom made rear spare mount and tire cover. This helps offset the added tongue weight with the cooler.*
Blue tent is in excellent condition. Screens are good with 2 repaired small tears @ 1" and 1/8".
All zippers work very good.*
Custom made Door frame, of PVC pipe and expandable painter poles to have door at full height (gain 2" from the sag without)*
Mattress is the standard foam and great condition.
Optional Bed Cady Pockets*
Optional Add-A-Room/Screen Room. #*
Optional Detachable Window awnings.*(Little triangle shape 4'x1')
12'x24' tarp and aluminum poles, rope and pegs to put over the tent for longer stays to keep inside cooler than without the tarp.*
12' grass carpet to put under the tent and entry patio under tarp/awning.*
Indoor/outdoor carpet for inside dressing area to protect the floor.*
$2800
It's currently in NH.
Delivery/meet could be arranged.Attached Thumbnails![]()
