trailer wiring harness
Sep 1, 2012
5
Hudson, MA
Had to trike (Motor Trike kit) my 2008 GL1800 due to multiple knee issues. Now I need to install a witing harness for my trailer. I have the Kuryakyn harnesses (including the 5 pin to 4 pin for the trailer itself.) Has anyone seen an explicit "how-to" write up for doing this, including routing suggestions to get thru the trike conversion? I was going to have a local motorcycle shop do it, but they told me some of the connections work directly with the plug-in harness, but some connections have to be made directly to specific wires, so I lost some confidence with them. Anyone ever seen an article on this wiring? Thanks
Go to this link.
Trailer Wiring Harnesses | Touring | Küryakyn
There is all sorts of install instructions. Unfortunately none of them are gonna be MT conversion specific. You'll have to wing it a bit there.... :Coffee: :Coffee:
Depending on your installer the connectors you need to plug into could be a real bear to locate. I had my installer locate them up under the seat so I could find them then I did what I wanted after that.
Hope this helps.
Flyboy7312
