tour-pak relocator.
520fd
550+ Posts
Gold Member
Aug 9, 2010
498
376
Davenport, Iowa
Jerry
Say, Keven. I bought another tour-pak relocator from you. My 3rd one. I have a 2022 Tri-Glide. Got the package from you the other day. No problems whatsoever. I tried to get the Filler pad from J_P Cycles. When I looked it up, it said the filler pad would not fit the 2022 Tri-Glide. It said, it fits only Rigid mounts. Is there any difference between 2019 and the 2022? I know Harley installed some kind of locator, but that was only about an inch or so. What do you think?
Thank you for your business, we appreciate it! :)
I don't believe there is any reason that it will not fit the 2022. Catalogs and fitments are just not updated yet.
Going back quite a few years HD has had a 1" adjustment on the TG Tour Paks.
Regardless of the year, the stock screws are not quite long enough...they will work, with some effort, but many go to the hardware store and get some little longer (1/4" is all that is needed) fasteners.
Here's a video of me installing it with the factory fasteners...it was a PITA.
Thanks Kevin. I installed the relocation kit on my last 3 trikes. Easy install. Just wasn't too sure if the filler pad would work. Also, the kit is high quality. Top notch. Thanks.
Kevin, are you saying that I can adjust my 18 TG Tour Pak back an inch without buying a TP relocation?
The 1" adjustment on the stock set up is usually already back the 1" when delivered to the Dealership. But you can check and see if yours can move back an inch, or if it is already moved back.
sammiesfreewheeler
