Is there any problem with the wiring when putting the tour box back two inches?
Just a heads up. I installed the tourpac spacer a few months ago. Just got back from Rolling Thunder and 3k miles. Went to open tour pac and found all 4bolts were almost completely unthreaded. I followed the install directions to the letter so I don't know why they all came loose, but it's something to check on once in a while. Boy! that could have been a disaster.:AGGHH:
I agree plus use the correct locktite or you will have problems latter rmoving them without heat..Loctite is your friend when it comes to keeping your Harley in one piece.
Wow, I don't remember so well.
I think I better go back and take a peak see!
Sam
Glad to see I'm not the only one that had this problem. I hope the locktite works. I shake the box every time I get off the bike - paranoid I guess.
To be clear, I don't think it was ever said that this was a bad product. It was only suggested that installing the four mount screws without any loctite is a recipe for disaster.
I am happy with what this kit provides; a lift to the tour pak. But perhaps the installation instructions need to be revised to add a recommendation to use loctite on the mount screws.
Which bolts have been coming loose, the ones connecting the rails to the trike or the ones connecting the tour pac to the rails?
I have never been personally contacted about a similar problem with these rails before I ran across this forum post. The best possible solution would be for you to contact me personally and make arrangements to return the parts. I will refund your purchase price as well as the return postage. The last thing I would want was someone to be paranoid about a product I make.
I am sorry you are disappointed and have had a problem with my product.
Dennis Swan
tGLIDEstuff.com
Is the tour pak sitting level with no gaps when laying flat..not sure if your bolts are stretching also??Well it happened again. Came home from another 1000 mile trip and the 4 bolts holding the tour pack on the spacers were loose about 1/8".
I took out the instructions and read word for word and I did them all - 2 washers in the front bolts with lock washer. Last time I even put Locktite on the bolts - didn't help.
This time I installed the bolts kitty corner (staggerd)and will see if that works.
I still like the set up - just have to figure out how to keep from having to retighten the bolts every 1000 miles.
I have hit some pretty bad bumps and holes, but don't know if that has anything to do with the bolts loosening.
Any suggestions??
Any suggestions??
