Sort of found out what happened to my engine today. The rods were too tight, no side clearance. It had metal shavings on the crank In the brand new SE oil pump,In all my bearings, in the oil pan.It messed up the cams also. So Lou figures a SE crank & rods,new SE 10/5-1 forged pistons, new cams,he is going to sell me a new set of jugs & bore them .005 over with .005 over Pistons. He hasn't checked the new lifters yet. New oil pan cause he said the new pans you can't clean the filters anymore on them. I told him I have the 259e cams now but if he finds something better do it. I just said I want it done right this time. You can't trust the dealerships anymore. Anyone that doesn't know the right way to install rings the right way probably couldn't even mop the floor right.
I'll probably have to sell my new truck to pay for this!! The crank and rods alone are $1200. I told him my wife said just put a new stock motor in it & he said no you don't want to do that cause these motors coming out of the factory aren't worth a crap. He said this isn't the first time he's seen the rods with no side clearance. Where's the quality control anymore. The money you put out for these things you shouldn't have all these problems. I'll be lucky if this doesn't cost more than $5000. If I'd known I was going to have this much trouble I would've kept my Ultra. Never had a problem and didn't use oil. He still has to figure it all up & let me know how much. Jim
