Tired of stopping to turn on your GPS?
After searching through various forums all I could find is: you need to insert a relay, use your reverse button to interrupt the speedo input to the GPS blah blah. Well a little comment caught my eye about on the 2010 and newer Goldwing not needing all that work. So I gave it a try,
I cut the speedometer input wire at the plug just where the wiring goes into the trunk a 6 wire connector with a (white wire/black stripe) on one corner I cut this wire then ran the two extended wires (speaker wire works great) to my pocket on the right side, installed a switch just above this door, I used a switch that has a cover you open to turn on. Went for a ride. at any speed with cruise on I uncover, then flip my switch (now the wires are disconnected) give it a second and push my buttons to turn on my GPS , BINGO! GPS is on now I lower the cover on the switch which recloses the wires allowing the GPS to read input again. I used this style of switch because the covers come in various colors (mine is Carbon Fiber), most of these switches are metal, location gives some weather protection, mostly I can't inadvertently bump the switch and turn off the system.
NO MORE STOPPING!
When I had my '09 NAVI I didn't have to do anything to the bike to start the GPS just got it up to speed pulled in the clutch shut the engine off when RPM went to Zero reached down and started the GPS then restarted the engine. Sometimes I would have to do it twice but very simple.
Navi
Yeah that works, BUT my way your bike is on cruise, motoring down the road NOTHING is disconnected or shut off. If a situation occurs while the switch is flipped ... handle it then go back to pushing buttons. Your way is..... well dangerous, been there done that that's why I looked for a better way. Have a great day!
nmbr1soonerfan
