tire shredder kit on 2016 freewheeler
Jan 23, 2017
9
Rogers City
has anyone out there ever put a stage iv tire shredder kit on a 103 harley trike before i think im going to. but im going to have harley davidson dealer install it its gonna run about $4700 i just dont no if my 2016 freewheeler will handle the torque and horse power has anyone ever done this and have any problems??/ harley says it will void the warranty on it and i still have over a year left, i would really appreciate anyones input on this.
has anyone out there ever put a stage iv tire shredder kit on a 103 harley trike before i think im going to. but im going to have harley davidson dealer install it its gonna run about $4700 i just dont no if my 2016 freewheeler will handle the torque and horse power has anyone ever done this and have any problems??/ harley says it will void the warranty and i still have over a year left i would really appreciate anyones input on this
I have 2015 FW with a 120ST in it and it works real well. You shouldn't have a problem.
hello again sorry to bother u again but i have so many questions. i dont want to mess up my trike and its almost $5000 but did u have to do beef up the rear axle or change to a stronger drive belt thats what im worried about. the HD dealer said i should be fine. its a 103 to a 110ci not 120ci and could u tell me what kind of numbers u had on HP and torque
Around here, if you buy a 2017, they will upgrade the 107 cu.in. to the 114 cu. in. & give you an extra 2 years of warranty.
You should consider that route. That M8 engine is pretty sweet:clapping: Hell, with the cost of that engine+ the installation labor, you might come out cheaper.
I have a 110 crate motor in my 2013 TRI. TTS 100 cams, with TTS tuner, true dual exhaust, SE high performance air cleaner. Dynoed out at 107 hp at 4000 rpms and 104 lbs torque at 3000 rpms. The Torque curve is fairly flat. All subject to change depending on the day temp and humidity. Rest of the drive train is stock. 50k on the setup and no issues. Good Luck with your choice
That sounds like a 3 wheeler made to run on two wheels. Must be a heck of a beast to ride. Ride safe bro...
She is a sweet ride for real. I ride solo and I have coil over rear shocks and 30 wt in the front tubes. Handles great and rides nice. I can get it on with the best of them. Don't have their top end but I can keep up with most of them. Thanks
Trike#1
