tire pressure for trike
Just remember that trike tire pressure is different for the 2 wheelers. If you are riding something with automobile tires tgecpressure usually is much lower on the end with 2 wheels and if the 3rd tire is on a Stallion it's higher. My old Stallion I had 40psi front and 25psi rears, my Vanderhall Carmel has 25psi for all 3. If it rides like a truck, check for high pressure then check if you have adjustable shocks. Tomg
tyre pressures
thx for reply, i have car wheels on rear set at 25psi, front tyre 35psi, the rear suspension is adjustable by springs, which are fully up due to cornering, if too low the trike tips badly, not sure how to adjust the piston dampers on rear, and also front, looking at better suspension due too poor roads in uk against usa .
Stitch61
