The Coolant Goes In...The Coolant Goes Out
Sep 12, 2013
110
12
Baltimore, MD
Jerry
Wondering if anyone else is seeing consistent coolant discharge on their 2014 Tri Glide. Past 2 weekends I have filled the reservoir to the COLD line only to watch it flow right out upon parking. Looks like the warmer temps and 2 up riding are causing some issues with the water cooling. :(
I plan on talking to my local dealer this week. In the meantime, I'm curious if others are seeing similar issues.
Jerry
Had slight leaking problems when first purchased in October of last year. They changed the thermostat twice with the last one sent to them by Harley, and replaced the neck on the reservoir and solved the problem. No drips or since then.
They had problems with this early on. Get with your dealer there is a fix. Has to do with the cap and neck. Good luck
Pleased to announce the recall fixed the issue. Been riding in some hot temps and I gotta say the 103 engine on this bike is cooler than the CVO 110's I had without the CAT. No cooked right calf.
Jerry
ledgin
