tank badges
I'm hitting my inner knees on the stock tank badges. Any buddy else having that issue. How are they attached? 2014 Tri Glide.
Probably glued on you could take it off with dental floss running it between the tank and badge….Maybe do it in the sun so the heat will soften the glue….Then Use Goo-Be-Gone to clean the remnants of the glue off 👍
Never tried to get them off of my '14 TG, but I did on my '17 so that I could get pinstriping and lettering applied to the tank. They are stuck on with adhesive pads that are VERY persistent the '14 is probably the same stuff. The guy that did the paint work suggested WD-40 (a little at a time) and monofilament fishing line. Took me several hours to get both off, but it worked like a charm!
They are taped on . Use fishing line to saw off in between tank and badge using Goo B Gone as a lube .
Dieseluladstron
