Switching to LED lights
ItBeMe
200+ Posts
Sep 12, 2017
174
381
Carrollton, Ga
Lee
Has anybody ever switched over to LED lights. I have a 2002 Honda Silverwing that I want to install LED head lights & tail Bulbs are the bulbs interchangeable.
Thanks for any help.:clapping:
Many parts stores now sell them. Remove an old bulb, and they can probably match it. For the turn signal to flash correctly, sometime a new flasher needs installed.
Another option is to order in a kit from a online supplier that probably makes a kit for your bike.
https://www.socalmotogear.com
You might want to know that such lighting can be costly, and it's not as reliable as OEM bulbs. I've seen some bulbs not work out of the box while others only a couple of days. However, usually once the defective ones are replace, usually they will last a while. The link above will usually ship out replacements quickly.
nmbr1soonerfan
