- Moderator
- #1
Here's something to keep an eye on. The wife's 08 stallion (406) 60,000 miles started steering very hard. Looked at the front tire/wheel all looked good. I had rebuilt the front wheel bearings and pads 6 months ago. Looked at the linkage between the steering wheel and the steering box looked good. Disconnected the arm from the steering box to the triple trees and found that the trees moved very hard. Took the trees/steering head apart and found that the lower steering head bearing was completely destroyed (Rusted) the upper bearing was dry and rusted. There was very little grease at all in the whole assembly. Lower race in the steering head was rusted. Taking the steering head/triple trees apart replacing all the bearings and races is just like any other motorcycle just on a large bases.
Be careful with the threads for the nuts that pulls the bearings into the races. The top thread can be flattened real easy. I packed the new bearings like one would for a trailer axle. I also packed the steering head to keep water out. Steers fine now.
