***Stealth LED Run-Brake-Turn Lights- True Plug-n-Play Sportster***
Jun 15, 2013
9,117
8,814
Red Banks, MS
FINALLY
A TRUE PLUG-N-PLAY
RUN-BRAKE-TURN LED LIGHT​
DK Custom Revolutionizes Run-Brake-Turn LED's for 48's & 72's!
Measures 6.9" end to end, perfect for the 48 & 72 rear fender
Click ME for more information and pictures:)
IMPORTANT FITMENT NOTE: International Models (models made for, & sold outside the USA) have different wiring than Domestic Models (models made & sold in the USA) and the Plug-n-Play Connections will not work properly. The light will still function if you wire it up manually, however, we cannot support international installations of this unit. This is a Plug-n-Play for Domestic (USA) Models.
Kelsey
TRUE PLUG-N-PLAY RUN-BRAKE-TURN LED LIGHT
*For 48's, 72's, Irons & Nightsters!
**Will fit some Dyna models that use the same Harley connectors as the Sportster 48's, 72's, Irons, & Nightsters.
***If you have a different Model, or would like to save $ and do your own wiring, check out the Universal Stealth RBT LED HERE.
Click HERE to see more details and photos of Our Plug-N-Play RBT!
Similar threads
Gyl
