Starting issue with my 2023 Tri Glide Ultra
May 20, 2024
Portage, WI
I went on a 100 ride yesterday. Stopped at a leather shop for about fifteen minutes. Went to start my 2023 triglide , and nothing. Fuel pump cycled but other than that nothing it would not start.
Made sure it was in neutral. Turned switch on amd off a few times and it finally started.
Anyone have any ideas?
Just might be a one time glitch I know you say you had it in neutral, but I do know the machine will not start unless you step in heavy on the brakes in gear …. my new side-by-side I’m not starting even in neutral without stepping on the brakes maybe the new tri glide incorporated that?… But if this is a one time deal, I’d say was just a glitch!
Hello & welcome to Trike Talk. :)
Could be a one time issue. If it happens a few more times it may be something in the program.
Welcome to Trike Talk
Check your connections @ the battery and the starter, also check your main (50 amp) fuse, grab it to make sure it is tight and does not wiggle
If that happens again try applying the brake and then starting even though it shows you are in neutral. If it starts then there could be some type of sensor that needs attention.
Welcome!
Try moving around your fob as to where you carry it.
I keep mine in my windshield pouch and sometimes have to move it around in the pouch for it to let the bike start.
Is this the first time it's done this? I have heard that some security systems in a business can mess with your security. It's never happened to me, but I remember seeing this on a post on here or another site.
MagicEagletrike
