Starter safety switch
Hi VW Trike Lovers :wave4:
I am trying to set up a safety switch on my clutch pedal so the starter will not engage until I depress the clutch.
I have started my trike several times in gear, while I was working on it. Dam near ran myself over.
I have a Arizona Trike Kit. Stock 1600 with 4 speed.
If you look close you will see the clutch pedal in pic.
Pedal pulls the cable witch operates the clutch.
Has anyone set up a switch to shut down their starter on the clutch pedal of their Trike ? I know a lot or standard shift cars have them.
asset.php
Thank's
TrikerBilly
Hello.
Yeah, I have been living without one also.
Maybe some sort of micro switch somewhere on the linkage. Best place is probably on the shifter as a neutral switch.
The hydraulic clutch units have an option of a switch on the cylinder. Other than the hydraulic kit I do not know of any others you can buy. Some of the late/last models did have a switch on the side of the trans.
Most likely you will have to make it all the way.
My Dodge Dakota has a switch on the clutch arm under the dash. Any auto parts will have one. Hook it to the ignition wiring. A relay would make things easy to do.
I would think it should be pretty easy 2 hook up 1 of the universal stoplight switches on the trans end. You would need the relay kit though. Depressing the clutch would pull the switch and allow it 2 start. You could probably put a bracket on the engie bolt.
I think Deathbysnusnu is on the right track. That spring loaded micro switch would be just the ticket.
I don't personally care to have a neutral safety switch in case clutch goes bad I can still start the trike in gear, but I understand why you would want one.
Yup that switch is what I had in mind. I don't know if it can handle the amps. I have the relay kit on mine because sometime all u get is the solenoid click no start. This is pretty common on old vw's.
Mine has a hydraulic clutch. I was thinking of using a brake light switch between the master and slave cylinders to interrupt power to the starter solenoid. The starter would only engage with the clutch pedal pushed in.
BikerBobs2
