You have to figure the combined weight, then figure how to get enough weight ahead of the axles. That would be tight, you need 12' just for the Stallion, then the wing beside and in front. When I was shopping, no one offered a fifth wheel with a big enough garage. If you had one built to spec, you could do it but the cost would be up there!!! You would be looking at three axles, and you'd have to figure on at least 16'. Most likely giving up to much living space. I've full timed in a 40' Carriage 5th wheel, and can't even picture fitting both of your rides in it.
Your best direction would be a coach, with a pull behind trailer.
