Spedometer using magnet on driveshaft. Or something. Need help!!!!!
Dec 29, 2015
78
51
Louisiana
Ok. This post pertains to my deisel trike build... So, the Spicer 3053a has no output or anything for a speedometer. It's designed to feed a divorced transfer case and the speedometer is attached to it. I've seen speedometers that work with a magnet on the front wheel. I would really prefer something that would work off the driveshaft. I've seen analog, electric, GPS (not fond of the GPS idea), sending units that I have no idea what goes with what, etc. I'm totally ignorant to universal speedometers so any help that can be provided would be appreciated.
Mr trike
Hello- VDO makes a 3 3/8" face speedo that works great. I have used hundreds of these in the VW application. On the VW, you JB Weld 6- 1/2" magnets on the CV joint equal distant apart then mount a sending unit so the face is within 1/4" of magnets. Run the 2 wires from the sending unit to back of speedo. Follow the directions in box to calibrate speedo to your tire diameter. This will work great as long as the 1/4" spacing is constant." Keep-On-Triken"
Cline
