windsurfed
150+ Posts
Ok, so I buy a HD Smart Siren 2 for my 2020 TG. ($109.95) Install was a breeze. The TG has to be violently shaken before any alarm sounds. You can push it, sit on it, open the trunk, open the tour pak, turn the ignition switch on, (without the fob present) and no alarm sounds. Seriously, it physically has to be shaken violently before any alarm sounds. First violent shaking produces a long chirp sound, shake it a couple seconds later and you get another long chirp sound, finally shaking it violently a third time and the alarm goes crazy for only 28 seconds.
On a 2 wheel HD Motorcycle, you take the bike off the jiffy stands and immediately the alarm sounds, just as you would expect it to.
I have looked all over and far as I know there is no sensitivity adjustment on the Smart siren 2. Even called HD service. If anyone knows different, let me know.
So it’s pretty much worthless for a TG. Except, if some unknowing suspect doesn’t know all this and cuts a wire leading to the Smart Siren Alarm, or pulls the main fuse, or disconnects the battery, or even unplugs the Smart Siren 2, then the Smart Siren 2 will definitely sound off loudly.
It might sound off if it is being loaded at an angle in the back of someones truck. Haven’t check that yet.
