slow speed wobble
Dragon
250+ Posts
Dec 28, 2010
288
72
oly,wa
Hello
More advice please. I have a slow speed wobble when I start up from a start. it has kinda a wobble
real faint but I feel it, and when I go around a corner from a stop it is more noticeable. at highway
speeds it drives just fine. I tightened
the front bearings a little more and tightened the head bearings
and it still wobbles. thanx
Dragon
This sounds like a tire may have a separation. That is the way my work trucks start acting when a tire is starting to come apart. The back ones are easy to have a tire shop check. See if they will take a good look at the front one for you while it's on the trike. It's not fun when they come apart while you're driving. We've had them come apart on the trucks and it's not fun, that's why I pay attention to my employees when they say the truck is feeling funny. Good Luck Rick
Even though you tightened the steering head you might want to check to see if the bearings in the head are okay. Mine the lower bearing rusted away and one of the symptoms that something was wrong was a wobble besides hard steering. Replaced the bearings in the steering head well lubed, and it never has steered better.
Hello
I should have stated that, I have replaced, steering head bearings, pivot bearings on down tubes,
caliper rebuild, new shocks, new tire and sent the hubs to tbms and got everything replaced, new axle
I guess I have just about replaced everything.:xzqxz:
Thanx
Dragon
I agree with Gorilla, I know you said you put a new tire on so it sounds like something is not tight. If you take the weight off the front, can you shake the tire or see a wobble in it? I would try jacking the front tire off the ground just enough to clear and then spend the tire checking to see if it touches the ground.
Hello
Dragon
Some trikes do have a slow speed wobble on take off and it's no big deal.
I have ridden trikes with that tendency. it's faint and At highway speeds it goes away.
Does it do it if your lugging the engine around town? If it is keep your trike running in a gear where it's always pulling.
Does it have a raked triple tree? is your front tire inflated to the max.?
that may be a cause?
Is this part of the learning curve?
Good news
I had to replace my float pins so when I did that I checked everything
from the bottom to the top, I had a little play in the fork when you move
it from side to side and I could follow it right up to the steering arm.
the steering arm would move slightly but the steering box shaft did not
move. the nut holding on the steering arm was just a little loose so I tightened
it. where the steering arm connects to the steering shaft mine has a cone
arrangement to keep it tight. tighten the nut pushes the cone tighter.
went for nice ride and this seems to have solved my problem.
Dragon
Good news
Dragon
There you go good job of diagnosing and repair.
Eddienorman
