Siren goes off when clutch lever is pulled!
Feb 21, 2016
351
122
Madisonville, KY
Rick
I installed a 2 wire piezo siren on my trike and everything chirps when you turn it on and off with the fob nearby but....when you have the key on and all indicator lights are out, you pull the clutch lever in, the sound starts wailing at you! Also if you start the engine it does it also. I don't have the electrical manual for mine and was hoping it was in my service manual, but nope that didnt work out! Anyone have a suggestion as to what is wrong?
after posting, related posts popped up and i am going to try these tomorrow
No idea how to help other than to say that the wiring diagrams are in the very back of the service manual in Appendix A . . . at least they are on every Harley service manual I've ever had.
Good luck getting it tracked down.
Thanks Jerry, I had those out but not sure why it sounds when in neutral or when I pull the clutch in. I tried everything that was in Old Sarges' post from 2015 but still no luck.
Not sure Fuzzy, would the neutral switch sensor come into play by just squeezing the clutch lever in?
Sitting in gear, engine off, all ok. When you 1)Squeeze clutch lever, sounds off or 2) reach down and move the shift lever to neutral, sounds off.
Right now I have the thing unplugged so I can ride!
dyno56ca
