Over the last couple of trips with the Stallion my shock pressure will drop within 10 minutes. Has anyone else had this issue? I would appreciate advice on how to fix the problem. Jerry126
you might try spraying and light soapy water spray at the compressor line fitting behind the rear seat and check if you have a leak there you will see bubbles to try and find the leakOver the last couple of trips with the Stallion my shock pressure will drop within 10 minutes. Has anyone else had this issue? I would appreciate advice on how to fix the problem. Jerry126
