Front shock adjustment
Aug 1, 2010
164
27
Effingham, SC
Oddoman
I BEEN HAVING A ISSUE OF A ROUGH RIDE ON THE FRONT SUSPENTION ....I TRYED TIRE PRESSURE ADJUSTMENT WITH NOT TO MUCH SUCCESS....AND THE I LOWERED THE SHOCK DOWN TO THE NEXT LEVEL....WHAT A DIFFERENCE...THE SHOCK FROM THE ROAD IS A LOT BETTER...SHOULD HAVE BEEN DONE LIKE THIS BEFORE...
ODDOMAN
#667
EFFINGHAM, SC :wave4:
They make a spanner wrench that fit those slots in the bottom of the shock, but I put a shop rag around it and used a large set of channel locks pliers. It turns pretty easy if you jack it up so the front wheel is off the ground. Hope this helps Steve
I used a wrench that works on most bikes for that adjustment....i sure can tell a difference...dave
oddoman
# 667
effingham, sc.....
Front shock adjustment is great, but I DO NOT recommend touching the rear shocks. I did and had a heck iof a time resetting them back!!! You can read my posts on the suspension setting I posted a few months back.
Tomg
I didn't stop at the first level on the front shock. I found, the lower the better ride ... now like a Lexus.
teddycarnes
