shock ajustment Lehman trike
Mar 2, 2011
18
Boise Idaho
Can any of you smart guys tell me if the rear shocks on a 1800 lehman are adjustable? the back end is saging pretty low and with a trailer on it is too low. need to stifenit up or see if it can be raized. thanks in advance for your help.
i wonder if the tri-glide rear lift kit will fit yourtrike, i got mine from tGLIDE stuff.com
you might contact him and see.the name is case sensative or the site is 8th down fron the top if you click on show tGLIDEstuff only. mine was 1 1/2" lift. hope this helps
There are 5 settings on the auxiliary shock on the Lehman Monarch II conversion. They are normally set at the middle position during assembly so there should be 2 more steps of preload that you could go to. If that isn't enough, Lehman does offer a heavy duty auxiliary shock that is a direct replacement. It can be ordered through any authorized Lehman dealer.
mudrock
