Shadow Aero with Motor Trike
Hello!
I'm considering purchase of a beautiful, first affordable trike, a Honda Aero 750 with a Motor Trike Kit installed. I'm 6'0" tall, 30-1/2" inseam and 350 lbs. wet. What are the limitations with this trike setup? Are my legs too long? Body / mass too large? Any and all comments welcomed.:)
Note: My current ride is a Honda Helix scooter (cn250 / 244cc) with 8" Tow-Pac installed. It's fairly easy to get up to 60 mph, though 65 mph is certainly a stretch.
John
John my first thought would be that it would be under powered.A lot depends on what kind of riding you want to do.If you are happy with the Helix then maybe the 750 would work.If you can test ride the 750 that should answer some of your questions.Good Luck/RIDE SAFE
I agree with Lucky. Only you can tell if it will work for you. You are getting a bigger machine should ride better. The preformance is going to depend on where you ride and what you expect/need. Hope you can test ride it before you have to decide. Good luck
that range is a little low unless you come across a real deal. the vtx 1300 honda is probably your best choice in that cc range. good luck
after thought are you interested in a vw trike? they can be has in your price range. go on e-bay or craigs list and search
In addition to my 82 GW trike, I have a 09 Shadow Aero 750 trike. Have had no issues going 2-up with GF and towing a 110 lb Lil Clipper trailer with another 100 lbs of cargo. That's roughly 550 lbs total.
i ride two up on my 06 aero with insta trike, no complaints, and they handle much better than a solid rear axle. i saw a guy hit a 6"curb with one of his wheels the bike stayed straight as an arrow, that sold me on mine...
Vinny1007
