trikes4ever
In Memory of Bob Reeves
I just finished adjusting the float level on a TC88b CV40 carb. I used the procedure in the HD manual - the best I could. Also consulted with my indy - who says he's always just eye-balled them and bent the tab until the valve closes with the float parallel to the bowl mating surface. I find the official HD procedure confusing and complicated at best. Tilt the carb 15-20 deg, measure the distance between the 'perimeter' of the float and the sealing surface, bend the tab until this distance is between .413 & .453 measured with a vernier caliper...
What I did in the end was to do my best with the HD procedure, and then verified by blowing very gently on the gas line (I keep the gas line attached to the carb when I remove it) with the carb in its normal upright position while gently raising the float with one finger until the float valve just closed. You can't use too much pressure as it's easy to force the valve open, and also must use very light pressure while raising the float as there's a substantial lever arm. Doing this I confirmed that the valve just closed when the float was parallel to the bowl sealing surface.
Seems to me that what I did to confirm might be an easier and more straightforward way of setting the float level from scratch.
Would appreciate any comments by the carb experts out there.
